gearbox help needed.
Bought another gearbox in the hope that i can make one good gearbox from two, but any advice/help would very much be appreciated.
So i,m going to strip it again once it passes it,s M.O.T.
I know second gear going kaput is a common fault on nc29,s and this meshes with sixth gear so could this be the problem?
but for some reason i,m not convinced that it is the gearbox, it only seems to do it under hard accelaration.
I,ve bought everything from new clutch, chain and sprocket kit and rear wheel bearing,s and so on just in case it,s somthing else, but i,m at a loss and need help before i start.
P.S the person with the winning ansewer can place a donation to 400 gb on my behalf and generally feel pleased with themselves (LOL).
Re: gearbox help needed.
just out of interest how easy is it to get to the gearbox on a 29?
best peice of advice i can give you is constantly double check everything your doing and take as many photos as possible just in case.
best of luck if you go for it.
do you know if you have to split the casings?
(if i can do it, anybody can do it), granted i made a mistake in not checking all the gearbox components hence why i,m doing it again.
I am not to bothered had the head off and cams and stuff out last year but I think my gearbox is on the way out (I will find out at cadwell on the 2nd) but I have a good gear box here so I think in the winter I will swap the gearboxes and may as well re ring it while I am at it.
