Expansion tank overflow hose split nc23
itscrossy
Post by itscrossy »
I've put my nc23 back on the road after ten years of being sat round doing nothing after a few tweaks everything is running fine, the only thing I gave noticed is that the overflow on the expansion tank has split.
Will this effect the cooling system?
Will it be losing water?
And can you repair the hose without replacing the whole expansion tank?
itscrossy
Re: Expansion tank overflow hose split nc23
Post by itscrossy »
itscrossy wrote:I've put my nc23 back on the road after ten years of being sat round doing nothing after a few tweaks everything is running fine, the only thing I gave noticed is that the overflow on the expansion tank has split.
tanuki
Post by tanuki »
nope its an overflow....clue is in the name.
you will only loose coolant through this if something else has gone horribly wrong or you have overfilled the coolant.
