ignitech
hunter
ignitech
Post by hunter »
Has anyone fitted a shift light using the ignitech unit.
The manual says terminal number 12,but there is no female connector in the plug.
Re: ignitech
IIRC if you want the shift light or quick shifter for that matter you need to specify when ordering or it wont come wired for them
hunter
Re: ignitech
Post by hunter »
Thanks DM,But if i wire it will it work.
Re: ignitech
If it hasn't been wired from factory your need to open it up to do so not something id want to do
hunter
Re: ignitech
Post by hunter »
The male pin its there on the unit,But no female or wire in the plug.
RickOliver
Re: ignitech
Post by RickOliver »
Give me a call or drop me a mail - I have plenty of the Ignitech tags that go in the connector block and I`ll explain what you need to do (it`s actually quite simple,,,)
Rick
hunter
Re: ignitech
Post by hunter »
Thanks Rick i will give you a call,
When i can find your number.
RickOliver
Re: ignitech
Sorry - missed you last night but try again today, I`m in all evening...
01603 720387
Rick
hunter
Re: ignitech
Post by hunter »
Ok thanks Rick.
hunter
Re: ignitech
Post by hunter »
Got to say a big thank you to Rick Oliver,
For all his help with this.
Nice to talk Rick.
