nc30 cdi plug - engine 4 pin plug promblem
crazyman
Post by crazyman »
hi , i'v been buying up parts for my bike , found that the 4 pin plug out the cdi box is a male plug and the 4 pin one in the loom is a male plug , were things changed over the years or am i missing something , cheers
vic-vtrvfr
Bike owned: NC30 x4, VTR1000 Firestorm
Re: nc30 cdi plug - engine 4 pin plug promblem
Post by vic-vtrvfr »
Sounds like you have the wrong cdi.
Nc30 cdi has 2 plugs, one black, one white & both female.
On the plus side, I have spare cdi here if you need one :)
crazyman
Post by crazyman »
here is a picture of mine
crazyman
Post by crazyman »
what part of the world do you live vic-vtrvfr ?
is your loom on the bike? are you plugging it into the right plug, there should be two next to each other and another couple of plugs for the brake lights and what not.. perhsp your tring to stick it int he wrong hole.
the cdi looks ok.
it is a nc30 one by the looks, 2 plugs both male (has pins) and black / white.
crazyman
Post by crazyman »
the 6 pin plug is fine but the 4 pin on the engine that go's to the pickups is the same male plug , the 3 engines i have are all male plugs as well , guess i can just cut it of and fine new plug for it , must be diffient model or something
crazyman
Post by crazyman »
i must be missing part of the loom from cdi to engine plug
hunter
Post by hunter »
You must be,the pick-up plug into the harness near the engine,
The CDI plugs in under the seat.
Try tracing the wires back from the pick-up plug.
crazyman wrote:the 6 pin plug is fine but the 4 pin on the engine that go's to the pickups is the same male plug , the 3 engines i have are all male plugs as well , guess i can just cut it of and fine new plug for it , must be diffient model or something
unless you dont have an nc30 engine there is no difference between l,m,n models of nc30 ignition plugs and loom.
pictures engine numbers etc would help.
nc30 loom
