Brake piston damage / corrosion
Swingarm
Bike owned: AR 125, NC30
Post by Swingarm »
So I planned on stripping and overhauling the brakes. Whipped everything off and then realised I couldn't get the pistons out without reattaching the master cylinder, lever and hoses
So I did a bad thing - I used an adjustable wrench and a rag to pinch the tops of the pistons to gently lever them free
In doing so I marked each piston. I hate myself so much for being so ham fisted and lazy
They marks go no lower than 1-2 mm and will likely not even make it to the dust seals, but I did file down any roughness, using jeweler files. This of course removed a small amount of plating
My question is, do I need to worry about corrosion going under the existing plating and getting to the piston seals?
I am a naughty boy and I must be punished :(
richyrd5
Regular Member
Re: Brake piston damage / corrosion
Post by richyrd5 »
naughty..naughty..lol..as long as they have been smoothed down and wont go to the fluid seals you will be ok,
bgrundies
Post by bgrundies »
hi, you can use a foot pump or even a bike pump to pop out your pistons but beware they fly out like a bullet. make sure the bleed screw is closed, wrap the caliper in a rag. put the end of the pump hose on the banjo bolt hole and give a short quick blast. if the pressure escapes put a rubber oil seal between the hose and bolt hole. as you know the area cleaned up will now be prone to rust and if you fit new pads the piston will be deeper into the dust and oil seal. on dual pistons you can chock them so both come out equally then reduce the thickness of the chock until they can be removed. again be careful.
Swingarm
Post by Swingarm »
Thanks. Very helpful
