RE: Clearance issues with fork tops raised above yoke
marty400
Post by marty400 »
Hiya All,
hhmmmm... thinking about CBR600f Uppers on a NC29.
However, longer than the 400 fork tubes, so will need to stick out a bit over the yoke....
How high can the fork tops go above the yokes, before clearance issues with the Screen brace at full lock etc?
I measured 30mm clearance at full lock.... it that to tight?
hope you can advise
Regards
Martin
marty400
Re: RE: Clearance issues with fork tops raised above yoke
Post by marty400 »
Can the cbr600 fork tubes be cut down, and everything still fit internally?
What are the internal unit lengths though like, compared to std dampening rods etc.
Martin
Ps: Fork tube lengths found:
Nc29 fork tubes are approx 6cm shorter!
(What about the the fork lowers as well?!)
Cbr6:
Fork Tube Honda CBR 600 F3 95-98, 1 piece, Diameter 41mm, Length 633mm, OEM Part Number 51410MAL601
Nc29:
BRAND NEW "ABE" FORK STANCHION FOR HONDA CBR400RR GUL ARM.
NC29.1990-1994.LENGTH- 572mm,DIAMETER-41mm.
Nc30:
533mm from forum post
