FZR400 3tj Forks.
FZR400 3tj Forks.
I have an FZR400 3tj front end of unknown vintage on my bike and I am going to be doing a complete fork rebuild over the winter.
my question is on the bushes... Are ALL 3TJ fork bushes the same over the models life? - I everyone wants me to give a year or exact model before supplying them, and I dont know which year the forks are from.
they are (unfortunately) not the fully adjustable ones - just the standard 3TJ forks.
thanks
ALex.
thanks
ALex.
Re: FZR400 3tj Forks.
As far as I know they're all the same
I think the seals are thicker on the SP so make sure you get standard rr parts.
thanks for that - I will order them now.
ALex.
ALex.
Bollox i have just ordered the wrong seals for a SP then?dobbslc wrote:I think the seals are thicker on the SP so make sure you get standard rr parts.
http://bdkraceeng.co.uk/tc/products.php?151
- Bike owned: FZR400RRSP FZR400 HYBRID RRSP
Should be fine. Sp & rr stantions same diameter.
Might need a little persuading, there's a mm difference in height I think so they will go but they might not!
Well the new seals were taller than the seals I removed, by roughly 1mm funnily enough
so maybe the wrong seals were fitted previously. It all went together fine and didnt leak on the ride out today so all is good.
