Chain Tension
- Bike owned: RVF400 (NC35)
Chain Tension
Hi folks.
Looking at the chain on my NC35 - I hear that chain slack should be 20mm-25mm. Is this correct? Measured where? It doesn't seem much. My R1 had 45-50mm.
Looking at the chain now - with the bike on the side stand, on the bottom of the swing arm there is a black plastic protector thing - I can push the chain up so that it touches that - but the chain doesn't strike me as loose though.
Cheers folks!
Cheers folks!
- Bike owned: RVF400 RGV250
Re: Chain Tension
I just replaced mine and the box (regina) says 10mm - 15mm. Haynes manual says more than 40mm will damage the swing arm, cant find a value in the book though.
And I would guess you always measure half way between the front and back sprocket. That is where it will flex the most
Re: Chain Tension
I guess I need to readjust (ha!) my mechanicalling (yup. That's a real word) skills as well as my riding after going from the R1=>NC35.
- speedy231278
Re: Chain Tension
The original UK Honda handbook states 15-25mm.
Re: Chain Tension
Thanks guys.
Looking at my chain - slack it is here
and here is pressed up
This shows a difference of about 19mm - however when fully pushed up it contacts the black plastic thing on the bottom of the swing arm - so I can't push it up any further.
Does this still count as 19mm?
Part of me says "nope...you *could* push it further if the plastic swingarm-guard wasn't there" but then another part of me says "yup - that's fine, because it would sag lower down if it was stretched more"...
I'm sounding like a noob here....but measuring the chain on my R1 was pretty straightforwards...and I was never able to push it up to contact the swingarm...
Thanks for your help guys.
Re: Chain Tension
I don't know what is written in the workshop manual for your bike; but when I check chain free play I measure from fully pulled down to fully pressed up.
You appear to be measuring from how the chain hangs naturally to fully pressed up only. !
Re: Chain Tension
willandrip wrote:I don't know what is written in the workshop manual for your bike; but when I check chain free play I measure from fully pulled down to fully pressed up.
Well both yes and no.
I'm not pulling the chain down...but also when I did, it didn't move down from where it was hanging...
- Davez29
- Bike owned: NC29 forever
Re: Chain Tension
Whether I'm right or wrong I just measure slack from its resting position and pushed up to reasonable tight, not straining it tight. Always on its wheels and I tend to run it at the slack end of tension as I worry if it tightens then my output shaft may suffer.
Re: Chain Tension
And can you push the chain upto the swimarm?
