Inline fuel filter on xjr400 93
Struggling to find any info on this, but I'm fairly sure my bike has no fuel filter. Does anybody have any experience with these aftermarket inline fuel filters.. Will it mess around with pressure in the fuel lines/carbs?
Also if anyone has any workshop manuals on the xjr400 it would be appreciated.
Re: Inline fuel filter on xjr400 93
Do you have gravity feed carbs or fuel pump ? You can hear a pump ticking when you turn the ignition on.
If not the your fuel filter will probably be on top of the fuel tap - take the tank off and roll it on the side then unbolt the tap and clean the gauze filter.
I think the engine is like an XJ unit, have a look at the XJ600 manual
Aye; the tanks on them are conventional without a fuel pump, Boris.
An inline fuel filter will not effect gravity fed carburation until it becomes clogged and restricted.
Kayla had one of these; and jolly nice it was too.
Thanks for the replies, fuel filter has been ordered!
See, I don't think it needs it and if it isn't standard I'd be loath to fit one
1993 she needs a fuel filter,especially after cleaning the carbs
- Bike owned: Yamah XJR 400
There is a filter on the fuel tap inside the tank, take the whole tap out to clean it.
