Bodywork rattling, think grommets need replacing,
racingt
- Bike owned: NC35, Shand Stoater plus
Hi guys, the rubber grommets that hold the bodywork spigots seem to be worn out, and not holding very much. Plenty of rattles. Where is the best place for replacement? What do I ask for?
Does anyone use any other techniques to stop panels rattling?
Re: Bodywork rattling, think grommets need replacing,
http://www.cmsnl.com/honda-rvf400rr-nc3 ... partslist/
check the partslist first
http://www.cmsnl.com/honda-rvf400rr-nc3 ... ml#results
here is the reulsts for the cowels.
the gromits are instock, if you press the "more info" button you can get the part numbers, like number 4 is 64246mj4670
this is the number you need to give to anyone else you may order from such as Rick Oliver, David Silver Spares, Lings Honda etc.
racingt
