NC24 needles
- Bike owned: RC30,RC36,NC24,NC30,NSR250
NC24 needles
I'm almost done with my crabs and I want to confirm the following :
115 mains
5 hole emulsion tubes in the rear 4 in the front
35 pilots
2.0 turns on slow and
Needles marked 8ZG no washer
float at 6.8mm
Also why are the float valves drilled ?
Shawn
NC24,NC30
115 mains
35 pilots
float at 6.8mm
Shawn
NC24,NC30
Re: NC24 needles
float valves drilled? the floats are inside the carb that sit in petrol.. i dont think they are drilled else it woudnt run?shawntex wrote:I'm almost done with my crabs and I want to confirm the following :
115 mains
35 pilots
float at 6.8mm
Shawn
NC24,NC30
Do you mean the CV slide? Don't drill it, if somebody else has drilled it they probably made the bike run worse.
There should be a washser under the needle on standard carbs.
Re: NC24 needles
Pics of finished carbs built by Billy Carr . The float valves are new they were produced by a machinist who could not find any for his bike , he was kind enough to part with these.
IMG]http://i59.tinypic.com/6jj980.jpg[/IMG]
