Apart from the length what are the other differences? Are the stem and lock nuts different? Had a look at fitting the nc35 yokes and adapter kit to my 30 tonight and the diameter of the stem and lock/top nuts seem very different.
Also I have a set of NC30 head bearings are these the same as the 35 head bearings? I was expecting to have to press the bearings onto the stem but they seem to slip on?
Nc35 nc30 stem differences
- 28hodge
- Bike owned: '91 NC29 / '93 NC30
Re: Nc35 nc30 stem differences
Hi, when i look to bearing ref they seem different. Nc35 has same as nc29 but different to nc30
I don't know for stem or lock nut, but if you notice that stem is very different... bearing should also
I have put a complet triple clamp (ses from Gavin) in order to feet 675 fork, so i have used std bearing and nut... I can check diameters if u need
Chère
Gougou
Chère
Gougou
- 28hodge
Yeah I have got a set of nc35 yokes with stem but have non of the nuts or lock nuts etc to go with it so I am going to need them I think as non of the nc30 nuts etc will fit!
Nut and bearing are the same as nc29
You can have a look here http://www.cmsnl.com/honda-vfr400r3-199 ... ml#results
- 28hodge
Reckon if I buy this then the lock nut and top nut will fit then?
http://www.ebay.co.uk/itm/151401604899
That's why i told u that nc29 nuts are the same28hodge wrote:Reckon if I buy this then the lock nut and top nut will fit then?
- 28hodge
Cheers goulime
