Bolt thread size FZR 400 RR 3TJ lower triple tree
lacher
Hi all,
I have a problem with the 43mm (3tj I think) forks that I bought. Well I had several problems but most of them got solved.
I don't have the bolts that tighten the lower tree. I thought they would be metric but they aren't and I can't find the bolts online.
I know they are M12 bolts, I think 30 mm long, but I don't know which thread size. They are not metric.
If anyone has a link for the two bolts, or know what thread size they are I would be very happy to hear.
Thanks in advance.
Not a clear picture but you can see the bolts go in, in the outside of the lower tree.
Thanks in advance.
willandrip
Re: Bolt thread size FZR 400 RR 3TJ lower triple tree
They will have been metric fine = 1.25 pitch originally.Not a common bolt in M12
Are you sure you are not using 1.5 pitch which is easily available instead ?
If not; they could be whatever thread some oaf has retapped/ chewed them to .
You get the same craic with s/a spool mounts; people force in a 1.5m pitch bolt and destroy the fine thread.
M12 x 30mm 1.25 pitch Allen bolt
I've got a spare bottom yoke with bolts if you want it
lacher
Perfect thanks a lot! I didn't think about the fine metric but you are both right. I think I can easily find it around here, or maybe ebay.
I really appreciate your offer Evilchicken0, but I think it will be allright. It depends if the T piece will be straight or not since I'm sure the PO crashed it.. But I think I'll find that out when its on the bike.
lacher
Allright I have found the bolts in a shop nearby.. Expensive though. 15 euros for two bolts! But atleast I have them now. Thanks for the help.
