Gk76a Carb tops
				gsxrscotty
- Bike owned: 600Srad,600K1, ZX6R, ZX7R
Gk76a Carb tops
Does anyone know if there are any copy carb tops for these carbs or other bikes that use the same ones?
2 of mine have small cracks where the bolts go through where the previous owner has over tightened them and i guess from age and heat making them brittle.
I know these are now a discontinued part from suzuki
Many thanks
Many thanks
				dobbslc
Re: Gk76a Carb tops
I'm sure someone had a set for sale on here a while ago.
				gsxrscotty
Re: Gk76a Carb tops
Ok thanks,
If anyone has any for sale please let me know.
				3253bast
Re: Gk76a Carb tops
Part number 13502-17E20 should work on these carbs too. They are used on the 94-96 RF600F carbs just like our 13502-33c00 were.
				morris147
Re: Gk76a Carb tops
Got about 3 sets split up into bits. will check how many i have.
				gsxrscotty
Re: Gk76a Carb tops
Thanks for that, ill have to try that. Cheers3253bast wrote:Part number 13502-17E20 should work on these carbs too. They are used on the 94-96 RF600F carbs just like our 13502-33c00 were.
Super! Give me a shout if you do please. Thanksmorris147 wrote:Got about 3 sets split up into bits. will check how many i have.
				Marsbar
Re: Gk76a Carb tops
Hey, you are able to get new OEM caps from www.fowlersparts.co.uk using above part number they are in stock but are £38.46 +delivery,
If Morris is un-able to sort you out with some caps i have set of dismantled carbs purely for spares i could post out for the cover of postage and a beer token?
				gsxrscotty
Re: Gk76a Carb tops
Marsbar wrote:Hey, you are able to get new OEM caps from www.fowlersparts.co.uk using above part number they are in stock but are £38.46 +delivery,
£38.46 each + delivery
 Thats like the side fairing bolt/hanger/fixing things that bolt onto the engine. Something like £23 EACH!!!
I havent heard anything yet mate. That would be fantastic and help me out no end
				Marsbar
Re: Gk76a Carb tops
Hey,
Sent you a PM, hopefully it went through as i can't see it in outbox :/
If it didnt any chance can PM delivery address, if before 4:30 i should be able to get them in the post today
				morris147
Re: Gk76a Carb tops
I forgot to check!
Abit busy trying to get my gsxr set for the next race. Ill pop a reminder on my phone!
