draining battery
draining battery
As title says something is draining the battery on my bike. If I remove battery its holds charge but when left on the bike within 2/3 days its down to 2volts.
I know these can be a pain to find just wondering if anybody know where to start or common faults
cheers
cheers
- Bike owned: Nc30, CBR600
Re: draining battery
Having a read here would probably be the best place to start:
viewtopic.php?uid=16&f=24&t=912&start=0
Just one of those times to get the wiring diagram and meter out and start tracing
Cheers mate. good link I'll have a go at what It suggests hopefully find something thanks very much
Tried removing earth lead and and getting voltage from frame to battery earth terminal but nothing at the fuse box anybody got any idea where to go next also tried unpluging all connections I could find but didnt seem to make a difference
Would be worth checking insulation of your cables in case it has worn through somewhere and its going to earth that way
Found the problem after removing fairings and chasing wires all night last night went out tonight first thing I checked the rectifier
bloody hate electrics cheers for the help pal
Im glad you found it mate, always a good feeling to find an annoying fault. It was only at the last minute i realised you had a cbr as i was looking thriugh the vfr wiring diagram
