Quick Battery Question
After looking on the web for a battery for a 90 NC30 project WTF I found a YTX7A-BS which I've ordered, today I pulled the old battery and its a YTX9A-BS, Anyone know if the 7 will fit or will I have to change it.
- Bike owned: NC30 MV F4 Kwak Z900
Re: Quick Battery Question
The YTX7A-BS is the correct battery for an NC30, the YTX9A-BS is off a cbr600 and gives larger capacity but just fits.
Hi there,
The 7 is standard, the 9 is an option. The 7 has a capacity of 6Ah, while the 9 has a capacity of 8Ah. In reality, either is perfectly good capacity-wise. The 9 is slightly taller than the 7 but the footprint is the same.
Thanks.
Thanks.
Thanks for the quick reply guys.
- Bike owned: nc30
dont mean to hijack thread but does anyone know of a smaller gel battery for nc30?
got clearance issues with standard battery and custom shock,trying to find smallest battery that will do.
The smaller the number the smaller battery (e.g. as above 7 vs 9).thrasher wrote: got clearance issues with standard battery and custom shock,trying to find smallest battery that will do.
Most 2-strokes use a size 4. None of the smaller batteries have the terminals around the correct way for nc's, you'll probably need lengthen the +ve and -ve wires.
Check http://www.tayna.co.uk" onclick="window.open(this.href);return false;, theres a wizard for putting in dimensions, if you do that it'll tell you all the batteries they sell that are the same size :)
They do some dinky AGM (absorbed glass mat) batteries, but the prices can be scary of some of the more fancy batteries.
So anybody know what is a good battery for a track bike that's not running lights only starter and ignition?
- monkeywithaplan
- Bike owned: NC35 and NC30
rick oliver sells the YTR9-BS which is suitable for total loss. he sells it at a discount aswell, £65 i think.RVFJE wrote:So anybody know what is a good battery for a track bike that's not running lights only starter and ignition?
It depends how much faith you have in your electrical system. If it's all A1 (good reg/rec, stator, etc) then you could get away with a very small battery (rgv250 or similar).RVFJE wrote:So anybody know what is a good battery for a track bike that's not running lights only starter and ignition?
If you have any doubt, stick with a std size. It sucks to miss out on track time because of a dodgy charging system.
