FZR RRSP 3TJ7
FZR RRSP 3TJ7
Think ive owned this bike since late last year sometime and to date it hasnt turned a wheel, mainly because im lazy
but also due to being busy and a few problems along to way. Ive contemplated selling it a few times and sticking with honda but even with its shell suit 90's design and the issues it has theres something about it i really like so a for the meantime atleast its staying.
The main reason for not riding it so far has been the FCR's and the ridiculously long wait for BDK to weld up and retap some of the float bowls, i did have a set of CV's here for it but after discovering i also needed new throttle cables, choke cable, inlet stacks and airbox rubbers to suit the CV's i decided to wait as i really wanted it as it left the factory even if it was crap to fuel on the road. The FCR's did turn up maybe a month or so ago and eager with excitement i got some new float bowl seals and set about leak testing them on the bench, fail! the carbs leaked still from what looked to me out of the repairs that BDK did (sorry kris i didnt have the heart to tell you after the hassle you had with BDK). Totally pissed off with those they got pushed to the back of the cupboard and i haven't looked at them since, here they are in all their glory complete with restricted inlets
So onto the CV's, i managed to find in the box of spares a set of CV inlet stacks and fitted the carbs to the bike. Thats when i realised after lots of swearing trying to get the airbox on that the airbox rubbers were also different, abandoned that and cobbled up a throttle cable so i could atleast hear it run and after a few stabs of the starter it came to life
After some time i got a set of airbox rubbers softened up enough to enable me to fit the airbox so on with that and then the bloody thing wouldnt run, it would start, rev to maybe 3k ish, drop to 1k then die time and time again. Thought i should really strip and inspect these carbs and upon doing so im pretty sure there the reason it wont run, gummed up and dried stale fuel everywhere so there now scrubbed clean and coated with ACF50 to make em nice and shiney
Some monkey had ruined one of the slide rubbers by pinching it when refitting the cover so im just waiting on one of these and a spring for the pilot screw which was missing.
So thats where we are, still havent rode it but after many wobbles im keeping it ive even splashed out on a new set of Rosso 2's to replace the new dunlops that were fitted so im committed now lol. Id like to think im going to keep it standard but lurking in the loft is a full Ti system for one and a tasty ally rad so i dunno, Ive heard ditching the the EXUP makes the already bad midrange worse so im reluctant to remove the stock pipe but dam it looks sooooo heavy
Re: FZR RRSP 3Tj7
After dropping a screwdriver on the bench and scattering most of the jets all over the place i've been trying to work out what goes where, the task was made even harder as most of the markings on the jets are barely visible. From using a magnifying glass and basically holding the jets up to the light to visually tell them apart i think ive got them all in place but could someone confirm which is main jet and which is air jet position please
I've got bottom = main jet and above right of that = pilot air jet.
Also is there meant to be anything in that 3rd hole? theres a jet right down the bottom but its threaded all the way to the top as if theres meant to be something there
Maelstrom
- Bike owned: MC22, 3TJ1
Re: FZR RRSP 3Tj7
This shows a clear image of the main jet.
http://www.litetek.co/Guide_MikuniBDST_ ... qRing.html
I would suggest asking Matt Harper at Harper's Ultrasonic about the FCRs.
It is with his assistance that we were able to do the mid-body seals for the FCR.
cheers
Blair
cheers
Blair
https://litetek.co
https://litetek.co
maccas
Re: FZR RRSP 3Tj7
The jet to the right above the main jet is the starter jet for the choke circuit. The pilot jet should screw into the 3rd hole.
Dan
Dan
Re: FZR RRSP 3Tj7
Cheers guys, i managed to source another set of carbs although not in great condition i was able to rob them of the parts needed to complete the set i had. Still no joy with getting it running though, it started when i first fitted the carbs but cut out after a few seconds and haven't been able to get it catch since.
Carbs are thoroughly cleaned and set as per the manual
Carbs are getting fuel, pump primes and stops as it should
Plugs look new and are sparking, gap checked
My judgement maybe a bit off after spending night after night getting high on petrol fumes but anyone have any ideas? offers to buy? swap?
- mattUKNC
Re: FZR RRSP 3Tj7
Yes!
maccas
Re: FZR RRSP 3Tj7
Was this all off the starter motor mate? If so try finding some helpers to push you down the road. Might just get it going. Worked for me many times.
Dan
Dan
Re: FZR RRSP 3Tj7
Yep all off the starter motor, battery is strong though and turns the motor over with ease. Bumping it is out of the question I live on top of a hill so pushing it back up if it doesnt start will be a nightmare as I found out a few weeks back when we had to push the rvf home.
Ive just tried a new set of plugs to rule out the possibility that I killed the previous ones but still no joy, I was going to try the 4dx cdi I have spare but need to mod the loom slightly.
Im running off a aux fuel tank for the moment so the wiring connector isnt plugged into the bottom of the tank, will this make any difference? Just clutching at straws here.
Although the plugs are sparking I guess it wont hurt to test the coils if thats possible?
Re: FZR RRSP 3Tj7
Coils tested and they give no secondary resistance with the caps fitted but do without so caps are fooked, bit odd all 4 have gone together though isnt it?
