coolant reservoir location?
fewksie
- Bike owned: Husqvarna sm610, gsxr400 gk76
In a bit of a pickle and looking for some advice please.
As above its about the coolant reservoir, where should it be on the bike? has anyone replaced it with anything different?
also how do i go about draining the old fluid?, from what ive read there is a bolt on the water pump and i just undo this and drain the old, then do a mix of 50/50 and pop it in?
sorry to ask what might be a stupid question, there may be a few to follow though lol
Andy
- Bike owned: R1x2 98/2k/Gp125/73a/76a/76a
Re: coolant reservoir location?
hey,fewksie wrote:In a bit of a pickle and looking for some advice please.
On the rear subframe behind the side panel,pull the bottom hose off to drain fluid,bolt on pump to dispel air on refil....expansion tank is located at front on rad on my bike....
Hope this helps mate,
Andy
- GeeTee
- Bike owned: NC30 & GSXR750K4
I've also ditched the standard expansion tank and fitted the HRC kit
I tie wrapped the bottle to the coolant hose behind the right side of the the top radiator.
