stuck rear wheel
stuck rear wheel
Hey Everyone!!
As titled really, i won an auction on ebay which consisted of a rear wheel and swing arm but the main problem i found once getting it home was that the wheel was oxidised/fused to the hub! My main question is if any of you have had this problem and how did you separate it?
many thanks for any advise
chris
chris
Re: stuck rear wheel
hammer and a piece of wood usually does the trick,try a squirt of wd40 or similar for a day or two then go for it,or some heat if you have anything capable of putting enough heat into it.
cool thanks for the help, ill try it over the weekend!! will the heat not buckle or weaken the wheel or swing arm in anyway?
Use a hot air gun,Not a flame.
