It would be good if we could have a comprehensive list of replacements as a kind of FAQ, including mods required, weight (if possible) and recommended tyre section.
Can anyone help complete this list? Many of the quantities i'm guessing at, here
Wheel: NC30 Stock
Size: 18" x 4.5"
Tyre: 150/60-R18
Weight: 4.2kg (Rim Only)
Wheel: NC35 Stock - MC28 (NSR250) Stock or Magtek
Size: 17" x 4.5"?
Tyre: 150/60-R17
Weight: 4.3kg Stock, 3.4kg Magtek
Mods: None
Wheel: VFR750 Stock
Size 17" x 5.5"
Tyre: 170/60-R17 (stock) is 160 ok?
Weight: 5.8kg
Mods:modified Axle + sprocket spacers for necessary chain clearance (£125 from Rick Oliver, exchanges your old axle.)
There are apparently a couple of types of these VFR750 wheels:
vfr4 wrote:rdstars wrote:CMSMJ1 wrote:You need the one with the 5 rounded spokes too btw
Thanks, its the 5 spoked one ive put an offer in for, I did see one that looked like the nc30 wheel, still 17" and 4 nuts but I take it that one dont fit.
You're right, thats a 5.5" wide wheel which is too wide. Theres a bit of demand for them from VFR750 riders who want to change from the wheel you need (5 rounded spokes) to the 8 spoke type.
Wheel: Dymag NC30 - rare as hens teeth and cost heaps. New ones only available in 3-spoke? which I personally don't prefer the look of. Also subject to minimum order quantities for new.
Size: 17" x 5.25" (Magnesium) - 5.50" (Carbon)
Tyre: 160?
Weight: ???? (not much...)
Mods: None?
Steve from Dymag wrote:
Hi Michael,
I'm sorry but we no longer produce the 5 spoke single sided casting to suit the RVF400. We can still make the 17 x 5.25 from our 3 spoke cast mag range but a minimum order of 5 sets is required.
Wheel: Delkevic NC30 or NC35 - price ~£200?
Direct imitation of OEM wheels, no mods required
Weight: 4.9kg?
Please feel free to correct or add to this post, folks...
There are other solutions I have heard of, including a Ducati Dymag, which required machining at the back to make space for the brake bolts, NTV400/650 (mods required, can't remember what) Honda RS250 (spokes face the opposite way, requires machining also?)
Other effects of swapping to 17" rear:
HEIGHT
duh_ave wrote:
if you switch from the stock 18" wheel to a 17", get a hold of the RVF400 (NC35) pull-rod (dog bone suspension link).
It's 5mm shorter than the stock part which will give you 15mm more ride height. You'll need this to help correct chasis geometry issue the smaller wheel will create.
You can also have yours welded up and redrilled the 5mm shorter.
It also changes the rising rate of the rear suspension and makes it pleasantly more progressive.
So the ride Height is lowered, and this can be compensated by using a shortened/RVF dogbone or RVF Tri-linkage (which also uses needle roller bearings instead of bushes)
To increase the rear height past original for faster steering, do both.
(^^^ is this right? i mean does the tri-linkage change ride height, or is it otherwise interchangeable with no effect?)
GEARING
The diameter affects the final drive ratio between countershaft/road. So, with a 17" conversion your acceleration is greater (which is good) but a slightly lower top speed is achieved in each gear. A similar effect to if you added 1.5 teeth to your rear sprocket.
The speedo reports high by 4%, and if you want to rectify this by swapping sprockets, the required final drive is 2.564: 15F/38R gives 2.533, 15F/39R gives 2.6.
--edited...
