Page 1 of 2
nc35 wont start
Posted: Thu Mar 13, 2014 7:46 pm
by nicknc35#186
Hi,
My nc35 has been off the road for over a year and i have finally got my ass in gear and am in the process of sorting it out. The only trouble is she wont start!!! I have a fully charged battery and have checked all the spark plugs (all sparking fine) I have also cleaned the carbs but she still wont fire up! I get a little rumble but not enough to get her going. The fuel seems to be flowing fine so not sure what else to do. I cant even bump start her! Can anyone help me?
cheers
Re: nc35 wont start
Posted: Thu Mar 13, 2014 9:14 pm
by rcv4
drain the tank and try with fresh petrol,the shelf life on modern fuel is shit.
Re: nc35 wont start
Posted: Thu Mar 13, 2014 10:22 pm
by richyrd5
is the choke working.make sure the cable is opening the chokes.
Re: nc35 wont start
Posted: Fri Mar 14, 2014 8:35 am
by nicknc35#186
The choke is working fine I've checked the fuses and I have put new fuel in but still doesn't want to know!!
Re: nc35 wont start
Posted: Fri Mar 14, 2014 12:04 pm
by speedy231278
Vac hose on the fuel tap? Might possibly be that the carbs need a bit more cleaning?
Re: nc35 wont start
Posted: Fri Mar 14, 2014 11:00 pm
by skinnydog0_0
You could have flodded the bike trying to start it first time and killed the plugs.
Take them out and dry them on a gas hob or with a blow torch then try again. full choke no throttle.
Re: nc35 wont start
Posted: Sat Mar 15, 2014 4:10 pm
by racingt
Ditto, clean plugs. If you want go give a little encouragement, lighter fuel down plug hole, works as well!
Re: nc35 wont start
Posted: Wed Mar 19, 2014 10:27 am
by nicknc35#186
Cheers for everyone's help but still won't start! I've completely striped the carbs put new plugs in new battery and new fuel but she still won't have none of it! Really don't know what to try next? Any other ideas? Tried full choke no throttle but nothing really happening sometimes I get a little rumble but not enough to get her going!
Re: nc35 wont start
Posted: Wed Mar 19, 2014 11:33 am
by skinnydog0_0
Are the float heights correct?
Can you try jumping it from a car - to save your battery getting killed?
Also check that your kill switch is not stuck on or shorting. Is the side stand switch ok?
Re: nc35 wont start
Posted: Wed Mar 19, 2014 12:57 pm
by richyrd5
if its been standing for a while check the carb rubbers havent perrished or cracked.could be letting in air.
