Voltmeter wiring
Posted: Wed Mar 12, 2014 7:42 pm
by Repsolnc30
Hi have just bought the koso voltmeter to keep an eye on the voltage and charging system, I was going to take the switch live from the headlight and then other cable to earth, where would be the nearest earth at the front of the bike ?
Re: Voltmeter wiring
Posted: Wed Mar 12, 2014 9:42 pm
by bikemonkey
Left hand side, just underneath where the mid panel meets the lower
Posted: Fri Mar 14, 2014 7:27 pm
by Malc
Repsolnc30 wrote:Hi have just bought the koso voltmeter to keep an eye on the voltage and charging system, I was going to take the switch live from the headlight and then other cable to earth, where would be the nearest earth at the front of the bike ?
The whole bike is an earth. Bolt your earth to any bit of metal that is connected to the main frame. You don't need to use a specific earth point. You can in effect have an earth maybe one or two inches long should mounting position of the meter allow it.
Posted: Sun Mar 16, 2014 10:06 pm
by magg
Wire the voltmeter directly across the battery.
Posted: Mon Mar 17, 2014 4:03 pm
by dgunthor
i added a cigarette lighter socket to mine and have a voltmeter that plugs into it - can always use it as a phone charger / satnav power supply then
