Shim washers
Shim washers
I'm having the heads skimmed on my nc30 engine. Does anyone know somewhere that i could order washers to shim up the cam carriers.? I'm looking for 5 thou spacers.
Re: Shim washers
You cannot use washers,You will have to get some shim steel and cut your own.
- royster81
Re: Shim washers
Dyno tech in ballinderry might be able to help. Ring Brian and ask. He's a decent sorta fella.
Re: Shim washers
I'm sorted now, i looked up ebay and can buy shim steel. I didnt know what to look for before. cheers
