problems with 6th gear on my nc30
kelvin
Post by kelvin »
hi I am wondering if some one can help me on my nc30 when I go into 6th gear it is fine till when I start to try and accelerate it starts to make a nasty noise as if the gear box is not engaged properly or missed aligned. I have heard some thing about these having a weak 6th gear any help would be great and possibly some solutions thanks vince
jameswilco1
Bike owned: ZXR,VFR,DUCATI 916,WR400
Re: problems with 6th gear on my nc30
Post by jameswilco1 »
Sounds like it could be a bent selector fork or worn dogs. Possibly both. Either way i reckon it will need splitting and investigating.
Hope this help
dobbslc
Post by dobbslc »
What revs are you riding at when in 6th gear?
If it's very low revs with a worn out chain it could be lashing about.
kelvin
Post by kelvin »
hi yes it is at low revs but it has got new chain and sprockets on it and the chain is at the right tension, and with the gear selector and dogs would that just effect top gear because all of the other gears seem to be fine but like you said I think its an engine out job oh joy. thanks
dobbslc
Post by dobbslc »
If it's not jumping out of gear it's probably not the dogs or selectors.
It could be a chipped tooth though.
If it's at 2000 _ 3000 rpm in top then you're lugging the engine a too low a speed.
How bad is it? Can you get it up to say 6000 to 8000 rpm in 6th gear? If it's making noises at those revs then it's not just transmission lash....
kelvin
Post by kelvin »
it was between 4000-6000 rpm possibly higher it was fine when riding along the flat at approx. 50-55mph keeping up with the flow of the traffic them on the way home I over took a couple of cars steadily in 4th and 5th and when I went into 6th that's it started to play around and I tried going in and out off gear but like I said earlier it was fine at maintaining a steady speed but when starting to pull away started to make that noise
dobbslc
Post by dobbslc »
It sounds like your expecting it to pull from low revs in top gear, at 50mph I would have thought 5th would be better may be even 4th.
Remember the bike will do 60 mph in first gear.
bikemonkey
Post by bikemonkey »
5th and 6th don't like low revs.
Keep it above 6K rpm in those gears IMO :peace:
kelvin
Post by kelvin »
hi I know that they don't like low revs the nc30 im having problems with is for my son when he passes his test and I own a nc30 and a nc24 and I have not known for either of these to do what my sons one is doing and not known any of my other bikes ever to do in the past 25 years of riding motor bikes
bikemonkey
Worn or chipped gears then.
Not cheap!
