FZR400rr 3tj Front master cylinder
3tjben
One Hit Wonder
Post by 3tjben »
my front brake keeps going spongey and have managed to narrow it down to the master cylinder. For the life of me i haven't been able to find either a replacement or a rebuild kit, does anyone know of a place or if anyone's got one knocking around.
Re: FZR400rr 3tj Front master cylinder
Post by Evilchicken0 »
Try Wemoto .. I don't think they're much different from other Yam stuff but then again ...
If I had to say a similar bike if look at the FZR600R Foxeye, the disks are the same but its a heavier bike
rockTJ
Bike owned: GSX650F FZR250x2 RSV RG80
Post by rockTJ »
I think the genuine kit to rebuild the front master cylinder is part number 3TJ-W0041-50 (as per page 179 of the parts manual). You should be able to order this anywhere which can supply genuine Yamaha spares. Get yourself some red rubber grease too.
If this is no longer available then try 4DX-W0041-50 as this is the identical bike but UK spec.
Chris
bendy3
Bike owned: FZR400RRSP FZR400 HYBRID RRSP
Post by bendy3 »
I've got a few knocking around in the garage, I've swapped over to radial cylinders.
I use a radial too
