NC35 Troubleshooting
Posted: Sat Jan 11, 2014 5:46 pm
Hi all,
I bought an NC35 a month or so for a reasonable price, although I noticed that it felt starved of fuel at various revs.
I've serviced the bike with fresh oil and new air/oil filter. The sub filter on the air filter was falling to bits so I just removed it. I replaced the fuel and vacuum lines and I still had issues.
Sometimes the bike will start but before long it drops revs and cuts out.
I opened up the fuel tap and it looked okay. I performed the HRC mod to eliminate an issue with the vacuum/diaphragm and the issue is still the same. I will put it back together at some point.
I replaced the rear spark plugs as I had the tank off and they looked okay despite a little bit of oil present. It did turn over after this but died again after a few minutes.
The bike was stood for a year before I bought it.
What do you think it could be? Timing, HT leads or carbs that need cleaning?
