need a company to bore my nc30 cases, know of anyone?
james66
NOT TO BE TRUSTED
NOT TO BE TRUSTED
Post by james66 »
Hi all
I need a set of crankcases bored for my +1mm pistons in the new engine im building
Does anyone know of any companies that are able to do the job properly + straight apart from tts?
James
2013 Bemsee EDIasia F400 Sub64 Champion :)
NC30 + NC35 RS250 HRC aluminium rear axle group buy
viewtopic.php?f=78&t=45065&start=10
Morespeedvicar
Re: need a company to bore my nc30 cases, know of anyone?
Post by Morespeedvicar »
Isnt there any engineering shops locally that can do it, maybe worth a look in yellow pages.
james66
NOT TO BE TRUSTED
NOT TO BE TRUSTED
Post by james66 »
I could get it done no problem if the barrels were separate to the upper crank case half but cant as they are all 1 piece
kostritzer
Bike owned: NC30 track bike
Post by kostritzer »
Can't help with the boring recommendation, but where'd you find 1mm over pistons???
Dynapro in Runcorn have the contacts (if not the ability)
The dude is called Chris Neild (was on ere once? - few guys have used him as he has made some fast motors in his time)
Or, David Simon?
Bike_Nut
Post by Bike_Nut »
Tts in silverstone seem to have done a few
Oops see you knew about them
james66
NOT TO BE TRUSTED
NOT TO BE TRUSTED
Post by james66 »
The pistons are omegas, got them off liam, they are the same as the ones chris had
David doesnt bore he gets them done if he needs to, I worked with david for a couple of years + we done the camchain cbr400 together
Ive been given a possible contact in oxford so ill try them
Ahh..did not realise the cbr400 was with you :)
james66
NOT TO BE TRUSTED
NOT TO BE TRUSTED
Post by james66 »
It has given us many a headache + many hours work, ill have a camchain v4 running at some point this season to test + see how it goes, if it goes well it will be run with my +1mm's too so fingers crossed we should see some pretty good power
Morespeedvicar
I thought cam chains were a step backwards? Isnt that why aprilia had there gear cam banned?
