NC30 - NC35 Parts compatibility list
- BillingCBR
Had a thought earlier when I asked about fitting an NC30 undertray to my NC35, now, we all know that these bikes have many parts that swap straight over, or will fit with some modification, so I thought it might be useful to have a list of what theae parts are and if they aren't bolt on what you need to do to fit them. Feel free to add things as I haven't got all the answers! This chart applies in both directions, but notes will be included on which model is being refferred to if needs be, whether you'd want to apply them is another question! E.g fitting an 18 inch rear wheel to an RVF.
Rear wheel
Bolt on, including wheel nut and spacer
Front wheel
Bolt on
Brake discs
Bolt on[/b
Rear wheel
Front wheel
Bolt on
Brake discs
Bolt on[/b
- JC120
- Bike owned: NC30 NC35 RC30 RC45 MC22 NXA
- BillingCBR
Re: NC30 - NC35 Parts compatibility list
I thought you had to use the whole hub as the spindles are different?
viewtopic.php?f=24&t=36195&hilit=hub+sp ... 10#p261635
- JC120
Mine has the 35 spline with the 35 axel. The whole thing fits right into the 30 hub. Everything lined up, no issues.
V4ia addict
kostritzer
- Bike owned: NC30 track bike
It would probably be a shorter list if you listed the parts that aren't compatible!
makz2008
- Bike owned: NC30, NC35
question..
are the carbs compatible between 30 and 35s?
the throttle cables may need changing but is everything else compatible?
Yes. I and many other use rvf carbs on nc30's.makz2008 wrote:are the carbs compatible between 30 and 35s?
You need to use the rvf throttle pull cable - not sure about the push cable because I never use one. You may also need the rvf carb rubbers (different to vfr), I've always used them. That's it, everything else (airbox etc) transfers over.
