cbr600rr caliper upgrade
Posted: Thu Dec 12, 2013 9:32 pm
by phicise
Hi
Just wondering which master cylinder to go with calipers off a cbr600rr 03-04 model for my nc35.
I am upgrading now as am having alot of problems with the front brakes locking up. I have already changed caliper seals and master cylinder seals and using braided lines now but they still latch on after some riding which is quite scary. Brake lever wont release till maybe 15 minutes later. Any thoughts?
anyway,
Must i stay with the master cylinder off the same bike? or can i go with one off a newer model??
thanks
Re: cbr600rr caliper upgrade
Posted: Thu Dec 12, 2013 11:27 pm
have you got some aftermarket levers..cheap chinese ones ,aybe...
They need a touch of the dremel/file as they are not quite right. Fit some proper levers
Posted: Thu Dec 12, 2013 11:34 pm
by Cammo
CMSMJ1 wrote:have you got some aftermarket levers..cheap chinese ones ,aybe...
Yup, what Mark said ^
If the lever is putting slight pressure on the master cylinder when in it's out (resting) position then it can lead to boiling brake fluid and high pressure in the system. This has happened to quite a few people that are using non-standard brake levers.
There's no way I'd be riding it until it's fixed!
Posted: Fri Dec 13, 2013 4:46 am
by phicise
ive got stock levers though. What if the bike has had a fall before, do you guys think this may be causing the lever to always push down on the master cylinder?
il take it off anyway and give it a shave. see how it goes. thanks
Posted: Fri Dec 13, 2013 10:04 am
by BillingCBR
Is it a genuine Honda lever though? Where are you mate, might have a spare genuine one knocking about I can send out.
Posted: Fri Dec 13, 2013 10:55 am
by phicise
im in melbourne, australia. i guess it looks genuine. but i cant tell for sure. thanks for the offer, i just bought ordered one off the shop. hopefully it works out.
Posted: Tue Dec 17, 2013 12:39 pm
by phicise
just another question, i currently have HEL braided lines for my stock callipers and stock MC. When upgrading to CBR600RR callipers 03/04 , do i also need to change these brake lines and Banjo bolts as well ? or will my current lines and banjo bolts fit?
Posted: Tue Dec 17, 2013 1:49 pm
the lines won't fit - they have the wrong angle on the ends. Pain in the arse, but the brakes, once setup, are awesome.
