Rear brake master cylinder rebuild kit - alternatives?
- Bike owned: '89 NC30
Hi,
I'm in New Zealand and trying to find a rebuild kit for the rear brake master cylinder, at short notice. Is there a size I can ask the local (brake or motorcycle) suppliers for, or is it Honda/Nissin specific? I'd prefer not to order off eBay or from the UK as it'll take a week or more to get here.
Having said that, if I have no luck locally I'll order off Rick Oliver.
Matt
Matt
Last edited by williamshatnerspants on Wed Nov 27, 2013 1:36 am, edited 1 time in total.
Re: Rear brake master cylinder rebuild kit - alternatives?
You can find the part number here: http://www.akhara.com/nc30/nc30parts/index.htm
According to david Silvers website the part number has been superceded by 43520-MB2-315: http://www.davidsilverspares.co.uk/part ... 520MB2305/
It's not an nc30 specific part so your dealer should be able to supply it.
Thanks for that Cammo.
I forgot to mention I have emailed the local Honda dealer, and my wallet and I wait nervously for the reply. I see there are many stockists for aftermarket motocross brake cylinder rebuild kits in NZ, which are cheap, so hoping there might be something aftermarket that'd fit.
UPDATE: the master cylinder was fine it just took far too long to get pressure into the system. Don't be tempted like me to pull on the rear brake lever using a rope while lying on the left hand side bleeding the rear. It just doesn't f)(* work. 5 mins with an assistant and all was good.
Last edited by williamshatnerspants on Tue Dec 03, 2013 9:28 pm, edited 1 time in total.
- jetblack
- Bike owned: '89 NC30 SEED
Do brembo or any other manufacturers make a replacement M/C that fits the NC30? Mine is a bit worse for wear and i'd rather upgrade than rebuild...
