Tyga rearset swingarm clearance?
Posted: Mon Nov 18, 2013 11:42 pm
by starkey
Just wondering how close the tyga rearsets should be to the swingarm and if this is normal?
Re: Tyga rearset swingarm clearance?
Posted: Tue Nov 19, 2013 12:50 am
by Morespeedvicar
A miss is as good as a mile, but to be sure could you put a washer between the mount and the frame, give you a little bit of room. Or even file off the corner of the rearset if your desperate.
Ian
Posted: Tue Nov 19, 2013 7:45 am
That will touch...
I use big spacers on mine - do on all the rearsets I've ever used.
Posted: Tue Nov 19, 2013 8:26 am
by Drunkn Munky
^^^^This everytime. Are the spacers fitted?
Posted: Tue Nov 19, 2013 11:22 am
by starkey
yeah the spacers are fitted
Posted: Tue Nov 19, 2013 11:40 am
by 28hodge
shim it out with a washer.
Are the rearsets new? mine where second hand and must have had a slight knock at some point as when fitted with the big spacer they touched the swing arm and rubbed it, so i had to pack it out with a washer, then got a new spacer made to the correct thickness.
Posted: Tue Nov 19, 2013 12:38 pm
by starkey
yeah they are used which would explain it, will have to get a bigger spacer made up then.
cheers
