spark plug order
hoppy41
spark plug order
Post by hoppy41 »
just a quick one, feel bit daft :oops:
the spark plug leads, there marked ENG1,ENG2,ENG3,ENG4, they go into the corresponding cylinders? Forgotten which way round the go!
thanks
hoppy41
Re: spark plug order
Post by hoppy41 »
on my 93 bike the left (as you sit) coil does 2-3 and the right 1-4, this right?
Gidanski
Bike owned: 1994 CB400SF, 2008 CBR600RR
Post by Gidanski »
Look at the Wiring to the coils. They will both have a Black with White trace wire (Positive supply), the Coiil for Cylinders 1 + 4 will have a Yellow wire with Blue trace on the negative and other coil will have Blue with yellow trace on it. Coil lead position does not matter as long as the leads for the coil for 1 + 4 got to 1 + 4 and same for 2 + 3.
Also the cylinders are numbered 1-4 from left to right. Good luck with your bike.
hoppy41
Post by hoppy41 »
