Adjustable needles
Adjustable needles
Is there any need to use the standard 0.5mm washer when using adjustable needles in regards to does the washer serve any other purpose other than raising the needle? I ask as im trying out a budokan jet/needle kit ive had for a while and thinking back to when i removed the kit from a set of carbs a stock washer was used aswell.
hunter
Re: Adjustable needles
Post by hunter »
Just as you say,The washer is only there to raise the needle.
So using the adjustable needles means you don't need washers.
