Slipping Clutch
owen_captain
Bike owned: xs1100, xt250, VFR400 NC30
Slipping Clutch
Post by owen_captain »
Hi Guys. Just a kwik Q. Working on a mates NC30 and it is slipping a clutch, particularly when I gas it. I have set the cable to bite midway through the lever with enuff free play. Friction plates and steel plates are 100's but I did notice a little play in the basket. when I did have the clutch out, I did notice 1 of the 3 spring washers that sit behind the locknut is missing. Would this be one of the causes, I'm guessing it would.
Also, how much would the oil affect clutch slip as well. He is using Castrol 10w 40 Magnatech (semi synthetic) Engine oil and not bike oil. I'm also pretty sure this could be a cause for clutch slip :? If you ride the bike like a car :grin: then she goes fine, but then you might as well drive a car :mrgreen: but the minute you give it gas she slips. release the throttle a little and she takes. If you accelerate slowly, she won't slip much or not at all sometimes.
Cammo
Re: Slipping Clutch
Post by Cammo »
owen_captain wrote:He is using Castrol 10w 40 Magnatech (semi synthetic) Engine oil and not bike oil. I'm also pretty sure this could be a cause for clutch slip :?
That will be a problem. Friction modifiers in that oil won't be much good for a wet clutch.
Just google 'castrol magnatech 10w 40 friction modifiers' and see what other bike fans have to say about it: https://www.google.com.au/#q=Castrol+10 ... +modifiers
Re: Slipping Clutch
thats what happens when you use car oil in a bike
owen_captain
Re: Slipping Clutch
LMAO :grin: . Thanx Guys, thought so :P Will give the oil a drain and top up with some new oil. Another Q; must I pull out the filter and drain the oil thats in there too, or will a simple drain and refill suffice?
:peace:
speedy231278
Re: Slipping Clutch
Post by speedy231278 »
The filter won't drain properly unless you remove it. Plus, it will be holding oil that you don't want to be in the engine. For the sake of a few quid, pull it off and replace it. I'd personally also get some cheap bike oil to refill the bike, run it on that for a short period, then ditch it for some decent stuff to make sure you've flushed out as much of the car stuff as is possible. Also, if there's a clutch spring missing, you're missing 1/3rd of the total force locking the plates up, so I'd sort that out too.
owen_captain
Re: Slipping Clutch
Kewl Speedy. Will be paying my local bike shop a visit soon. :peace: Thanx for the advice man. Much appreciated.
owen_captain
Re: Slipping Clutch
[quote="speedy231278"]I'd personally also get some cheap bike oil to refill the bike, run it on that for a short period, then ditch it for some decent stuff to make sure you've flushed out as much of the car stuff as is possible.quote]
Can I use any oil, or the same viscosity oil? 10w40?
Re: Slipping Clutch
I'd also add that yes, missing one of the 3 diaphragm springs is going to cause slippage....
speedy231278
Re: Slipping Clutch
owen_captain wrote:Can I use any oil, or the same viscosity oil? 10w40?
10W40 is what H specify. I'm not sure if that might be changed if you are in a very hot or very cold climate. I know from working on my parent's cars that VW specify a range of viscosities depending on the expected climate, however I've not seen that for NCs. I'd just go with 10W40.
Re: Slipping Clutch
Yes.
Soemtimes the moly grease added to low friction car oils will stick on the plates of a wet clutch and become troublesome even with new oil. Perhaps it wll be ok you will have to check.
as above, you should try and replace the missing spring too
