Fork alignment nc30
tigerclaw
Fork alignment nc30
Post by tigerclaw »
Hi, I have rough assembled my front suspension and I was wondering how to make sure it is all true / lined up before I torque the various bolts. I figure that I could run string from the rear wheel past the front (assuming the rear is straight) then make sure the front is parallel to these lines (use something to lock / hold the front wheel in that position).... then .... how do I make sure the forks and triple clamps are square to the front wheel???? Or am I way off in terms of the whole process? Thanks
Haydn
Re: Fork alignment nc30
Post by Haydn »
If your forks, yokes and spindle are all straight then you shouldn't have any issues.
