Front paddock stand pin
britaxcooper
Post by britaxcooper »
Could someone please tell me the size of the pin required to fit up the head stock in order to use my front paddock stand? My bike isn't stored at home so I can't measure it at the moment
bikemonkey
Re: Front paddock stand pin
Post by bikemonkey »
27mm :peace:
EDIT: that is if you mean an NC30?
britaxcooper
Thank you :) yes nc30. I'll get one turned up as my stand only came with pins upto 18mm
mbikerdav
Post by mbikerdav »
i had the same, they posted u the wrong PIN - if its from a German company they are spot on, ring them up and they will post you the correct one free of charge (he said keep the existing one in case I happened to buy a new CBR1000!)
28hodge
Bike owned: nc30 (track) Yam YZ250 (MX)2st
Post by 28hodge »
Is this the STFL headstock stand, looking at buying one but their listings say that they only come with 5 pins the biggest being 18mm.
Did you just ask them to supply a different pin and they were ok with that?
bikemonkey
Yeah just send them a message and they'll add like £6 onto it
britaxcooper
I bought mine just as a univeral item so it came with the 5 pins as mentioned that go upto 18mm.
I had old Mini subframe mounting bolt so just parted it off and drilled a 13mm hole up the middle and used the 13mm pin provided :)
