Rear Set Release Mechanism Help Please
- lloydspencer
- Bike owned: NC29, RS250, Goose, RGV250 VJ2
I removed everything from my rear subframe so it could be powder coated.
I have put everything back together however I am struggling with the rear seat release mechanism. I have got it all back in the correct layout but I can seem to tighten the bolt so that it still works. It would rattle itself loose if I only did it up so it was working.
I may have lost a spacer or small part. I was hoping someone could supply a pic of a correct working part or if someone could explain who has experience with taking it apart.
When your Aprilia RS250 is more reliable then your girlfriend then you know it's time for her to go.
dunkenb
Re: Rear Set Release Mechanism Help Please
Try some thread lock on the bolt ???
- lloydspencer
Before I did something like that I want to know I have it in the right order.
If someone has a pic or can explain it would be brilliant.
