starter motor
starter motor
hi, can anyone please help, starter motor will not turn over. Bike has been standing a very long time. Engine may be seized,is there anyway to check?
I have changed the starter relay, though this makes no difference
1993 nc31
liverpool uk
1993 nc31
liverpool uk
Re: starter motor
is it possible to check if engine is seized by turning crankshaft bolt? anyone know were this is?
sorry to be bit daft
dave
dave
- Bike owned: 1CB400 SF 1 VFR800 1 Moto Guzz
Re: starter motor
The crankshaft can be turned by removing the hexagonal plug from the righthand side of the engine there is a 14mm bolt that can be turned with a socket and bar if the engine is not siezed.
- Bike owned: HondaCB400sf version R
Re: starter motor
As Superjack says this is the way. But first of all i think that if you don't have mechanic experiance it is better to give the sf to a mechanic. But if you still want to try it by yourself,i think that you must have the service manual.
Here some help for the first steps:
Take care,i think something is broken inside and if you try this work perhaps you gonna make more damage.
Re: starter motor
Where abouts are you, maybe someone close who may be able to help you.
Re: starter motor
Thanks for help. I removed the left cover. Typical
bolt turns 3/4 then jams. Im in heswall on wirral. Thanks
Re: starter motor
I think a valve maybe stuck. Would crankshaft jam if this happened?
Re: starter motor
Yes piston would hit it do not force it , If you remove the camcover it could be possible to see if a valve was stuck in the open position, in which case its a head off job.hoppy41 wrote:I think a valve maybe stuck. Would crankshaft jam if this happened?
