NC30 how to fit the clutch switch
Hi,
Putting my front suspension back together after powdercoating some of it. The little switch that fits into the "lever perch" for the clutch seems to just squeeze into place but there are two holes through the perch underneath the switch. Unfortunately due to the powdercoating I cant see any threads. Can someone look under their lever perch and let me know if there is a screw to hold the switch in place and if possible a picture or size / dimensions of the screw (I cant see a screw listed in the parts catalogue but it seems a little odd that it doesnt have one) - thanks
Re: NC30 how to fit the clutch switch
No screw, it just pushed in one way so removal is to push out from the terminal end.
Great - thank you
