Coolant drain plug sealing washers part numbers
AdrenalineJunky
Bike owned: VFR400 NC30
Post by AdrenalineJunky »
Hi everyone
After a nasty overheating experience yesterday, I have decided to flush the cooling system and change the coolant on my NC30. I had a bit of trouble finding the part numbers for the drain plug sealing washers that the Haynes book recommends replacing when you drain the coolant, so I'm posting them here in case it helps anyone.
90463-ML7-000 (6.5 mm copper sealing washer)
Re: Coolant drain plug sealing washers part numbers
AdrenalineJunky wrote:Hi everyone
The parts manual is in the documents library that has all the microfiche and relevant part numbers
Haydn
Post by Haydn »
It's just a copper washer, if you take it with you to any fasteners sort of place they'll be able to sort you out. I've fever replaced the one on the pump and it never leaks.
