Nc30 question - rear disc
				sp00ka
Is changing the rear disc and big job ? Couldn anyone give me a few intrustions ? Thanks
Re: Nc30 question - rear disc
Slacken Hub & wheel nut with bike on ground (36mm & 48mm)
Abba or Axel stands,
Wheel off
Undo hub pinch bolt (17mm)
Rear caliper off
Hub nut off
Slide sprocket/chain off
Pull out axel from hub
Undo 4 m8 disc bolts
Fitting is reverse of removal
Wheel off
Rear caliper off
Hub nut off
				sp00ka
Thanks mate , all sorted just need to order disc and I'm
Away
						Away
