left hand lower fairing bracket information needed please
isca1987
- Bike owned: Nc30
Hi I am having issues finding a lower left fairing bracket it's the one that holds on at the back of the fairing at the bottom. I think it bolts on to the side of the engine near the back. If anyone knows the part number or can get a picture it would be really helpful i have tried David silver and had no luck. Thank.
Re: left hand lower fairing bracket information needed pleas
It's discontinued a long time ago, nobody has stock.
http://www.cmsnl.com/honda-vfr400r3-199 ... ml#results
Microfiche is here.
Microfiche is here.
isca1987
- Bike owned: Nc30
After looking at the Haynes manual I think the bracket bolts onto the side stand I think it's number 1 in the picture if anyone can help i would be thankful.
The lower fairing brackets bolt to the frame not the side stand.
isca1987
- Bike owned: Nc30
Picture now added. Thanks
No 1 in that picture is the sidestand bracket.
If you have a side-stand on the bike then you already have that bracket.
isca1987
- Bike owned: Nc30
I have a side stand but where the old owner made it a street fighter he removed all the brackets and this is the last one i need
- alexwitham
You're after the bracket that the side stand slots into then, the little 'arm' with the thread in it, where the fairing is attached to via 1 bolt, is welded to the part that the side stand slots into.
From the original description by the OP I thought they want part 24 in the link I provided, this is the bracket in which the big No 3 screw with the rubber gromet bolts to in order to secure the lower rear of the side panel.
there welded to the stand bracket from the factory, mine fell off and then got rewelded but its wonky so need to make another idealy and just have it loose and mount under the m10 nut so I can align right,
