Flywheel puller
Flywheel puller
Can anyone recommend me a place to get one ?
Im based in Sheffield or an online place
Many thanks in advance Simon
Re: Flywheel puller
Just need a bolt m20 cant remember the pitch but im sure if you search itll come up
Re: Flywheel puller
You dont use one on the NC30.
After removing the 14mm bolt on the flywheel you will see a bigger hole.
Use an M20 x 1.5 mm bolt in that and it pops the flywheel off.
Re: Flywheel puller
Possible stupid question but where do I find a 20mm bolt?
- bikemonkey
Re: Flywheel puller
Same thing you are using right now, internet
Re: Flywheel puller
Bolt and fastner shop?Simon.J.Crossley wrote:Possible stupid question but where do I find a 20mm bolt?
Yellow pages under Fastners.
Rick Oliver sells them too
Re: Flywheel puller
just got myself one from ebay http://www.ebay.com.au/itm/160869693300 ... 1497.l2649 worked a treat easy as to get off , i used an air compressor & rattle gun though
Re: Flywheel puller
The Bolt Rick oliver sells is about 1gbp, so 2 aud or so.
Last bolt I bought was about 75p I think
