NC29 Help with Carb Part
Maelstrom
- Bike owned: MC22, 3TJ1
Hi All,
I am slowly getting these together. Still no sign of a float bowl I can borrow, but that happens.
Here is my question. What is part 16030-MV4-000 described as "Joint" Item No. 7 on the parts diagram.
I believe that it may be a rubber joint that connects the vacuum breather passage between carbs (1 to 2) and (3 to 4).
If it is then I will make them from viton and add them to the NC29 kit.
cheers
Blair
cheers
Blair
https://litetek.co
https://litetek.co
