Lower fairing fixings/Brackets
Hi Folks,
In the middle of putting the fairings back on the 89 NC30. The lower fairings are aligning with the mid section and nose cone fine. I appear to be missing 2 brackets though for lower fairing rear holes close to the rearsets/pegs. Does anyone have a picture of the brackets that I would need. Are they these;
http://bit.ly/11txAS3
Don't want to manufacture something dodgy if I can pick them up.
Any help much appreciated.
Cheers :)
Cheers :)
- 28hodge
Re: Lower fairing fixings/Brackets
I'm not sure these are the two brackets that you need one of them in the link I think is the choke holder bracket. But I may be wrong as road bike bits are not my strong point as I only own a track bike.
I will have the bits you need tho if you figure out what they are/look like!
The bottom left one is part of the sidestand bracket and may have snapped off on yours? The right side bracket bolts onto the lower part of the frame below the the footrest if you have a look you should see a threaded hole where it bolts on to.
- 28hodge
http://www.cmsnl.com/honda-vfr400r3-199 ... ml#results
part 1 on the attached schematic shows the left hand side lower bracket.
