Remove or add washer?
scubasteve
Bike owned: 2xNC30's
Post by scubasteve »
My nc30 has the common issue with the flat spot between 4-7k revs. I rejetted carbs earlier this year to 118/120 as I discovered it had 115/117 in for some reason and I have an aftermarket can. When checking the needles I found it had what I believe are none standard needles. They had groves and a circlip around the top so you can change height and look different to the picture in the guide. It also had the standard 0.5 washer. I decided to leave it alone and see what difference the jet change made. Unfortunately it still seems to stutter slightly between 4-7k revs if your not hard on the gas. I read thru the carb jetting thread and there seems to be conflicting opinions on whether to add or remove a washer to solve this as both running rich and lean can cause this problem. Can anyone recommend whether I need to raise or lower the needles. I was going to raise the needle 0.5m but now wondering if the stutter is because it's running rich rather than lean.
Morespeedvicar
Re: Remove or add washer?
Post by Morespeedvicar »
My nc30 hated the extra washer under the needles, i think the only way your gonna know is just try it and see wat happens. But i'd try lowering needles by a notch ie move the circlip up the needle one notch.
Ian
porndoguk
Post by porndoguk »
Adding washers or raising the needle makes the midrange 5-7k'ish richer
Im on factory pro needles with a 1mm drop on stock needles with no washer
Will report back when i get chance to take her out but on my last ride the flat spot was ever so small
scubasteve
Ok, thanks guys. Will raise the circlip to drop the needle. If I remember right it was on the third grove down with one 0.5m washer so probably quite a way out from where it should be.
porndoguk
Post by porndoguk »
steve85 wrote:Ok, thanks guys. Will raise the circlip to drop the needle. If I remember right it was on the third grove down with one 0.5m washer so probably quite a way out from where it should be.
heres a pdf of needle sizes etc to compare heights of your clip height based on stock ones
HTH
Rick
