nc23 carb proplems plz help :(
bido600
Post by bido600 »
hey guys
got nc23 used to work just fine till it shut down at idle
cleaned the slow jets worked just fine
suddenly when the bike get's warm the idle increase itself
cleaned the carb ( slow jets - big jets - pilot screw. found out that there is littile spring and washer under the pilot screw that was damaged and changed them ) closed the pilot screw and turn it 2.5 turn out
now the bike when its cold idle very good
when it gets warm or hot the idle increase again so i have to adjust idle speed till it idle again
but when i touch the throttle the rpm increase and stay up
then i have to adjust idle speed again and so on
please any help cause i had enough of this bike :whistle:
one last thing it used to rev to the limit makin that sound :stupid: now not :pray:
ZXESAS
Re: nc23 carb proplems plz help :(
Post by ZXESAS »
bido600 wrote:hey guys
one last thing it used to rev to the limit making that sound :stupid: now not :pray:
Mate your carbs are screwed so your better of rebuilding them or getting new ones my friends fzr400 has the exact same problem as you and we have done absolutely everything to fix them with no success so he is going to buy new ones! hope this helps! :peace:
The Novice
Bike owned: NC23 NC30 CRM250
Post by The Novice »
check your throttle cable isnt sticking. In addition spray some carb cleaner or similar around the base of the carbs and see if the revs alter - that would indicate an air leak, check they are seated properly.
It might be an idea to balance them and see if it helps at all.
bido600
Post by bido600 »
ZXESAS
i did the rebuild and still the same prob :( the prob that the carbs here are too expensive :(
bido600
Post by bido600 »
The Novice
checked no air leaks
all the cables are good
the only thing i didnt do the balance or sync the carb
but its not balanced could it do this ? :?
ZXESAS
Post by ZXESAS »
bido600 wrote:The Novice
Balance the carbs as well it might be the problem :peace:
