NC30 with Hydraulic clutch.
I saw an NC30 today with a hydraulic clutch (i'm guessing from the NC21) but gave up waiting for the owner to return to ask him about it.
I was just wondering why somone would do that, and if it's any better than the cable operated system? I'm always figured honda dropped the hydraulic clutch after the NC21 as it wasn't needed on the 400's?
I've got a complete NC21 clutch system in a box of spares I brought recently that I could put to use!
fastdruid
Re: NC30 with Hydraulic clutch.
The hydraulic clutch is 'better' in that it needs no adjustment or maintenance.
At the same time it's heavier, more complex (ie costs more to make) and more potential for failure in comparison to a cable.
Druid
Druid
- royster81
years ago i remember talk of bits from a firestorm being used to make a hydralic clutch,never saw the need for it myself ,but i might look into doing it to see if it can be done ....once i can walk and use both arms that is lol
- superlite
- Bike owned: TLS, LB80 x 2
Ah I see...superlite wrote:Anyone know what this one's off?
That's from the NC21.
- superlite
Nice, just a shame that NC21s don't exist in Aus. I assume it's a direct bolt on if you've got all the parts?
'Take it to the Back'
fastdruid
Looks identical to the VFR750 one.
I don't seem to have a better pic but by you can just see it here.
I'll check part numbers when I get home see if it is the same.
Druid
Druid
To be honest there are not that many in the UK either, (if anyone knows of a 400Z Naked NC21) let me know, I want its twin lights and bellypan :D oh and the 400K for its high-rise bars!
NC21 parts turn up on ebay quite a bit..
It's almost a bolt-on, you'd just need to trim the sprocket cover down a bit I think.
Druid
Just had a look in the 24/21 parts book (rev:7 04/92)
Hydraulic Clutch Slave Unit (Complete Asy): 22860-ML0-000 ¥3750
Sprocket Cover: 11341-ML0-000 ¥7,400
Druid
fastdruid
22860-ML7-000/22860-ML7-010 Cylinder Assy, Clutch Slave
Used in the following bikes
Thinking about it, I wonder what they changed, mine has to be the 22860-ML7-000 '88 "FJ" but I have an '89 "FK" which would be the 22860-ML7-010. I wonder if this may be contributing to my clutch slip when cold.
VTR1000 is 22860-MT7-000 Originally designed for the NR750!!!!
Druid
Druid
duncan
Neophyscist; Why not check out ebay item 130261799232 because the chap is breaking one of the twin headlamp nc21s.
