Refit Swingarm advice pleasase
mollers
Bike owned: 1990 NC30 uk, 2002 Blade 954
Post by mollers »
Afternoon to all ;)
Refitting my NC30 wing arm after a clean etc. Never done this before so stumbling around lol. :lol:
Question to all - when i fit the swingarm bolt with pivot adjuster slotted on,and then tighten it to the required torque (15nm) the swing arm goes from running free to being slightly tigh ?? ie it will sit at what ever angle you move it too. If i back it off to say 5nm it frees up again. Nut not fitted on the other side ??? Not a mechanic but would have thought the swingarm should remain free at all times ??? :roll: . Also dont have that special tool to torque up the swingarm lock nut :( only have one of those castle sockets from fleabay. Can it be tighened another way or am i screwed !!!!
All advice and wise knowledge received greatly
Cheers chaps :peace:
Adderboy
Re: Refit Swingarm advice pleasase
Post by Adderboy »
Is it all greased up? Re greasing spigot bearings and everything after cleaning?
As for the Honda tool I don't have one either but found another way, the socket won't work as you need to counter hold with an Allen key, which will be covered by socket, catch 22, I made a tool using a t-joint I got from work, usually for pneumatic systems, I wacked it on the miller and cut the 'castle shape' on one end, put a pipe as a handle on the side allowing an Allen key to pass through it, if you don't understand (I'm not good at explaining) I will try get a picture for you tommorow, the tool doesn't accurately torque it, but you can make a good judge with it
Hope this helps
mollers
Post by mollers »
Thanks adderboy. Pic would be good. Sorted the sticking issue, just stuck on how to torque this nut up !!!!
mollers
Am i screwed ???????
Post by mollers »
Evening to all ;)
Do i need that special offset Honda tool type thing !!! to torque up my swing arm locking nut ??. I only have a normal castle socket ( from fleabay) :pray: :pray: .
Is their a way to tighen the locking nut up without this special tool or am i ****** !!! :o :o
Can anyone advise ?? or point me in the right direction to buy one
Cheers :peace:
NC30 minus swing arm at present lol.
you don't need the offset tool - you can use the castellated socket you already have.
I refit mine when building my race bike and it just went in exactly as the service manual. You have got the proper Honda service manual haven't you? Get it from the downloads section..
mollers
Post by mollers »
Thanks CMSMJ1, was using just the haynes manual. Will download the proper stuff.
Cheers for the knowledge.
mollers
Post by mollers »
Hi CMSMJ1 :peace:
Just downloaded Honda service manual. The part i ment was the bolt lock nut. You need to hold the pivot bolt to torque up the lock nut. The service manual shows a special tool :cry: .
Only got the castle socket nut for the pivot bolt. Any ideas or am i on the hunt for ones of those special tools ??
bikemonkey
Post by bikemonkey »
I used the same thing you are on about, the ebay socket.
I had absolutely no problems torquing everything up, you should be fine, no need to hold the pivot bolt IMO :peace:
Adderboy
Post by Adderboy »
Tried to upload, failed miserably, it can't deal with size or something, shrunk it no difference sorry mate :(
Adderboy
Post by Adderboy »
Hurray!!
