Dented tank
- benny
Dented tank
Anyway of removing dents from the tank? I'm sure it will of been covered before but search doesn't show much. I have 4 down the right hand side.
DM104 for the road race team.
Re: Dented tank
it can be done i have done much worse but it invoves cutting the bottom out so you can work it from inside.
- benny
Re: Dented tank
So cut the bottom and weld it back on? IF the dents were pushed out would the paint likely crack and need redoing?
Re: Dented tank
Im sure a dent repair specialist could remove them without cutting the tank open.
- benny
Re: Dented tank
Know of any to recommend?
Re: Dented tank
the problem is you cant use anything through the filler neck because there isnt enough room,i have seen pins spot welded on then a slide hammer used by a specialist...but you need to hammer and dolly to finish it off,either way it would need painting.
- Bike owned: UK NC30 17" Rear.
Re: Dented tank
Definatley look into paintless dent removal before you look at cutting it open you will be supprised what can be done if you talk to the right outfit.
- benny
Re: Dented tank
Thanks for the help. Know any of the 'right outfits'
Re: Dented tank
Hi mate not in your area i am afraid ...........google paintless dent removal and ring a few up email them photos etc, i had a bad dent taken out a bonnet of a car and you could not notice they are superb, however it all hinges on if they can get inside to work the dent out.
Re: Dented tank
Might work out cheaper to get a second hand tank and have it painted?
